跳转到主内容
加入维修社区 - 创建账户
2021年10月发布的谷歌 Pixel 6 智能手机的维修与拆解信息。设备型号为 GB7N6 和 G9S9B16。
Display does not respond to touch
Phone was dropped, then the touchscreen became intermittently non-responsive. Applying pressure to the sides of the device or providing some flex would get touch functionality to restore for a while. Eventually even this stopped working and the touch functionality stopped working entirely although the display itself is still perfect.
I figured this must be a screen issue though I dont understand why only touch would fail and not display; so I ordered a replacement screen and hooked it up to test but again have the same issue, display works perfect with no touch input being accepted. I inspected the connector/board for the display and don't see anything wrong (although I dont have magnification). I cleaned the board side of the connector with 90% IPA though it made no difference.
Anyone have an idea of what to look for? I understand I will most likely need a new phone at this point but I'm still interested in what went wrong.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Have you rebooted the phone with the new screen attached? I had one one that needed it to be done twice before the screen was accepted and the touch then worked. You may even have to reset it if just a reboot doesn't work.
这个答案有帮助吗?
得分 0
3条评论:
Did old screen work? I have the same issue touch is not working even though there is no crack
由完成的
hi i have the same issue there was no cracks whatsoever is there anything u can do about it? or how did u fix it?
由完成的
My Pixel 6 Pro took 5 reboots before it finally recognized the touchscreen and started to work. I still had to run the google tool to enable the fingerprint detector, but that was rather trivial.
由完成的
添加一条评论
添加你的答案
Mike Meller 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 2,337
