跳转到主内容
Device and repair information for the Behringer Eurolive B212D speaker system.
32 个问题 查看全部
Why does my speaker quit after about an hour?
My speaker works great for approximately an hour or so then stays cutting in and out then stops working completely.
Update (10/21/23)
I found that one of the leads on coil "L1" has a bad solder joint. This would most likely be why it would work for a while then cut out as the unit heated up. I will resolver and give it a go.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@bruce66667 this "speaker works great" combined with that "cutting in and out then stops" leads me to believe that this is a power board issue. Possibly a bad MOSFET or other component. Open it up and take a look at the power board Behringer Eurolive B212D Power PCB Replacement for any discolored, odd looking component etc. Post some good pictures of it with your Question. That way we can see what you see. 在已经存在的问题里加入图片
Behringer Eurolive B212D Power PCB图片
指南
难度:
中等
30 - 45 minutes
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 1
1条评论:
@bruce66667 yes, that would definitely be an issue. Let us know if resoldering the inductor resolved the issue.
完成的
添加一条评论
添加你的答案
Bruce 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 56
