跳转到主内容
加入维修社区 - 创建账户
Mobile not vibrating software problem
Vibrate motor is ok bit. Mobile not
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@harmansand19435 so the only problem is that the vibrate does not work? Everything else does? How did you check the vibrate motor?
由完成的 分享
添加一条评论
1个答案
Hi @harmansand19435
Here's an image the vibrate motor trouble shooting flowchart from the service manual that may help.
There's also an image, one zoomed in and one normal size of the board layout showing where the components mentioned in the flowchart are located.
It the troubleshooting tests prove that the hardware is OK, then you may have to reset the phone back to default using a factory restore to see if it is a software problem. Note: Be aware that doing this will erase all your personal data and downloaded apps, so backup the phone to the cloud or a computer before you do the restore.
(click on image)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harman Sandhu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 276
