跳转到主内容
Fix your iRobot Roomba e5 vacuum with these replacement part DIY repair guides. Model Number e515020
Runs only short period of time
Runs only 10 minutes after charged, usually run at least 1 hr.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
There's an option to limit run time on the app setup. If you've ever used the irobot home app with this device, I'd start by making sure it's not set to limit run time in the app. If not, probably consider replacing the battery pack, which is a pretty simple task on these.
完成的
添加一条评论
1个答案
Likely, the battery is having an issue. When it stops working, does the battery take the full time to charge? Otherwise it could be an overheating motor or something like that
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Barry Meltzer 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 12
总计 166
