跳转到主内容
Repair information for standalone freezers.
20 个问题 查看全部
What is this beige goo in my freezer?
Hello,
I recently got a second hand freezer, and it has this beige goo in it (see picture).
What is the goo? Somethingto do with insulation? It seems to have decomposed a bit! It's sticky to the touch and there's a gap in the exit hole.
How can I fix it and how can I prevent it from happening again?
Thanks in advance for your help,
Michael
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Michael,
Hard to tell exactly what the goo is from the pic.
If the freezer is still functional you can repair the insulation with a can of 'Polyurethane Expanding Foam' from your local hardware store (search web).
Clean up the 'goo' first, with gloves on, try:
  • to physically remove as much as possible with plastic tools so as not to damage the freezer
  • then try cleaning with Metholated Spirits
  • If still residue, then clean with Acetone
  • dry completely
  • apply tape to cover the hole
  • carefully make a small hole in the tape the size of the foam applicator tube.
  • then spray expanding foam into hole via the tube on the can
  • you can put more tape over the small hole for a neater finish as it expands and dries
If you haven't used expanding foam before, try it on a similar sized hole in a cardboard box or other rubbish, to gauge how much you need. It has a unique behaviour and expands/grows very rapidly. Follow the instructions on the can carefully.
Regards
Chris
这个答案有帮助吗?
得分 0
1条评论:
Hey Chris,
Sorry for the late reply. I tried that today and it worked like a charm!
Thanks for the advice. Much appreciated!
Take care,
Michael
完成的
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 85
