跳转到主内容
The HP Deskjet Ink Advantage 1515 is an all-in-one desktop inkjet printer/scanner by HP. Model number B2L57A#AKY.
Why does my paper get jammed when printing
So whenever I print anything the paper get jammed any idea how to fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Paper getting jammed repeatedly is typically an issue with incorrect alignment, some obstruction in the paper's path, or an issue with the paper feed mechanism. Anything that can introduce a wrinkle. or a fold to the sheet of paper could produce a jam.
I would make sure everything in the path of the paper is clean and, inspect parts for signs of wear, be especially mindful of wherever the jam is happening (assuming it's usually in the same place).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ABDUL RAHMAN 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 6
总计 108
