跳转到主内容
The Ridgid 12 Volt drill/driver offers a compact, cordless unit capable of tackling projects within the office and household. This Hyper-Lithium powered drill bestows users with a longer lasting battery that doesn’t compromise on delivering strong torque output found across all Ridgid drill models.
How do you replace the carbon brushes on this unit?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Thank you so much for taking the time to answer my question oldturkey03 ! I will give this a try after the long weekend.
完成的
添加一条评论
1个答案
已选择的解决方案
@shawn123478068 so there really is nothing out about this particular tool. It appears as if they are "hiding" the brushes in the end cap. sort of like the Bosch, and Hilti's etc. have on many models. Kind of like this
I would use this guide Ridgid R82005 Motor Replacement and once you are at step 5, check the back. It looks like there are some locking tabs, marked by the blue rectangles
Now try to gently pull /pry the backing off. See what happens. I think the real work starts after that. Trying to find the brushes to match, maybe a PITA since nothing is listed on any of the parts sites. Not even with Ridgid.
While you work on your drill, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shawn1234 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 549
