What other iPhone screen glass only can I use
My screen i is cracked on the edge but no issues using it still except occasional glass bits I. Finger. Can I use the glass from and iPhone 6s to fix
@jodiegrover no, you can't. They are all different. I suggest you replace it with a proper assembly. Also, a glass only repair will cost you more than a complete assembly, since you will need extra tools and consumable to get this done. It is also not an easy repair, unless you have plenty of experience to do a glass only repair, Again, I suggest a complete replacement. It is less expensive and straight forward to almost guarantee success if you use the right guides. iPhone 8 LCD 屏幕和触摸感应器更换
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 9
