跳转到主内容
发布于2014年9月,灵越3542 第四代英特尔处理器
17 个问题 查看全部
Why my mouse pad is not orking
touch pad of mose not working
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
the mouse pad requires drivers from dell. go to dell website and enter the quick service number and you should be able to find them quickly
完成的
添加一条评论
2个答案
@nandu40616 this could be a driver issue. You did not tell us what you have tried and what OS you are using. Try this first:
  • Press Windows key + X
    Go to Device Manager
    Expand the Human Interface Device or Mice and other pointing device
    Look for HID Touchpad driver that was installed
    Right click and Uninstall.
Next go to this site and look for the Touchpad Driver. Install the driver, restart your computer and enable touchpad in the settings.
If that does not work, you must consider replacing the touchpad. You can use something like this video as your guide. Of course, you can also download the manual from here Page 45 will tell you how to replace the touchpad.
这个答案有帮助吗?
得分 0
添加一条评论
Make sure u try touch pad lock button and Trouble shoot drivers and try to plug in a USB mouse and see if it will pop up. While it's plugged in try to move your touchpad if it doesn't work you can try this
pull ur key pad up and check the cable ribbons. Check the touch pad ribbon and the keyboard ribbon and make sure they are PERFECTLY aligned if it's a little off it will mess up. Make sure u push it all the way in sometimes there's a white line on the ribbon that need to be aligned making sure u push it in where it's needed
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nandu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 11
总计 79
