location of speed sensor
I have a problem,code PO320,already replace crank sensor,still have same problem.
william, P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction. Possible Causes are :
- Loose wires/connectors
- Faulty Crank Position Sensors
- Arcing secondary ignition components (coil, wires and plugs)
- Low battery charge
- Powertrain Control Module
Possible Solutions:
- Secure loose wire or connectors Make sure you check the wiring harness, there is a tendency to shave through the insulation
- If battery charge is low, recharge or replaced battery
- Replace crank position sensor
- Replace starter motor
Since you already replaced your Crank Position Sensors, check on the other stuff....
Replacing the plugs, wires and coils might just be what you need to do. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 20
总计 4,391
2条评论
What engine size is it and what transmission do you have?
由 oldturkey03 完成的
6 cylinder with automatic transmission
由 Kenneth Dow 完成的
