跳转到主内容
加入维修社区 - 创建账户
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
location of speed sensor
I have a problem,code PO320,already replace crank sensor,still have same problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What engine size is it and what transmission do you have?
完成的
6 cylinder with automatic transmission
完成的
添加一条评论
1个答案
已选择的解决方案
william, P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction. Possible Causes are :
- Loose wires/connectors
- Faulty Crank Position Sensors
- Arcing secondary ignition components (coil, wires and plugs)
- Low battery charge
- Powertrain Control Module
Possible Solutions:
- Secure loose wire or connectors Make sure you check the wiring harness, there is a tendency to shave through the insulation
- If battery charge is low, recharge or replaced battery
- Replace crank position sensor
- Replace starter motor
Since you already replaced your Crank Position Sensors, check on the other stuff....
Replacing the plugs, wires and coils might just be what you need to do. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
william 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 4,662
