跳转到主内容
加入维修社区 - 创建账户
Frigidaire 冰箱 FRSS2623A* 的维修及相关信息。这是一款 2022 年上市的全尺寸冰箱机型,不具备内置或门上取水功能,但配备自动除霜功能。本页面涵盖了符合 FRSS2623A* 型号模式的相关信息。
Frigidaire Freezer Not Dropping Ice
Hi all,
I have a side by side Frigidaire freezer/fridge, model number FRSS2623AS6.
Water will enter the cube tray fine and freeze, but will not drop. When I cycle the control panel on and off (green button), the tray begins to rotate, but the feeler arm doesn’t go all the way down. If I manually push it down gently, it will go down and drop ice, then fill back with water.
I attempted defrosting for a little while, but that did not work. I haven’t taken it apart to see if maybe something is stuck or out of alignment with the feeler arm and motor inside. I’ve also attempted a reset, which also did not work.
I’ve attached a picture, and video at the best angles I could get with the bin still installed.
Any suggestions or thoughts?
Thanks so much!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
First thing I would do is to pull it out and let it completely defrost:
https://www.subzero-wolf.com/assistance/...
这个答案有帮助吗?
得分 1
2条评论:
Ok will try that in a few and see. Thanks.
由完成的
That was it.
I haven’t fully reinstalled, just plugged the harness back in to check if the feeler arm goes down on its own, and it did, once for drop, again for water recharge.
Going to let it sit out and fully evaporate any remaining liquid so it doesn’t refreeze after reinstall.
Thanks!
由完成的
添加一条评论
Hi @nicklemay
If it still doesn't work OK after you reinstall it, here's the service data sheet for the model series, that may help.
It describes how to manually run a test cycle on the ice maker.
If there is a fault and a replacement part is required, here's a parts list that may be useful.
Scroll across to the ice maker parts diagram to find the part and then the part number for the part. Then search online using the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
1条评论:
This is also very useful, thank you.
由完成的
添加一条评论
添加你的答案
Nick LeMay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 43
总计 2,611
