跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
20 个问题 查看全部
AMD stock fan unable to spin on its own.
My AMD stock CPU fan has been having issues starting on its own. Moves a few mm on its own, kind of struggling to start spinning. Really wasn't thinking acted more in panic, opened panel and slight finger push was all it needed. I did check to insure cabling was all properly connected. Advice on how to proceed forward.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@pz781n usually this may happen if the CPU fan is in the wrong mode. In the Bios, there should be an option for 3 pin or PWM for the CPU fan. You can look at the fan connector on the fan cable, if it has 4 pins it needs PWM mode and if it has 3 it needs 3 pin mode.
这个答案有帮助吗?
得分 0
1条评论:
Okay amd bios I have PWM and DC. I’m switch to PWM since I believe it has 4 pins. It was on auto. I’m shut down for a bit and then restart and see if that does it after few goes.
完成的
添加一条评论
添加你的答案
PZ781N 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
