跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 是任天堂发布的第七代掌上游戏机,是继折叠款 Game & Watch 之后,又一款双屏掌上游戏机。
Rewiring my volume control?
I have an old ds that doesn't work any more and i was wondering if i could tahe the volume control out of it and use it in my mint tin amp if so how would i wire it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Can u post pictures of the wires in question? Both, if possible?
由完成的 分享
If you know how to use an ohm meter, you should be able to figure it out, However...
It is not as 'cool' but buying the right value (both resistance and power rating) is probably a better bet. For not much money you can get the right part with all the mounting hardware.
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Give it a try. Take the potentiometer out of the DS carefully. It most likely will have three terminals. Connect your audio source to the right most terminal, connect the audio input to the mint tin amp to the wiper (the center terminal) and ground to the the left most terminal.
This is a fairly generic statement, assuming the pot in a DS looks like the kind in other toys. Basically you have a resistor with a sliding center tap. So you can use an ohm meter to determine which terminal is which. If the volume goes down when your expecting up, reverse the wires from left to right, leave the center tap the way it is.
这个答案有帮助吗?
得分 1
添加一条评论
I don't believe that you will have much success.
-Me-
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joshua 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 25
总计 2,761
