跳转到主内容
加入维修社区 - 创建账户
于 2017 年 5 月 23 日发布,是戴尔 UltraSharp 系列中一款支持 HDR 的 4K 显示器。
Gray blobs on screen
Just bought this monitor used. Works great, but there are gray blobs visible when viewing brighter colors.
The blobs have defined edges. Perhaps water damage or pressure damage.
Any thoughts would be helpful. I will repair myself, if that is possible.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Those definitely look like water spots to me. @oldturkey03 has a lot more experience with this than me, but my guess, assuming the spots aren't on the surface, is that there's a good chance you could disassemble the screen and clean the individual layers of polarizer, LCD and backlight. You just have to be very careful to reassemble everything in the exact same sequence and orientation you took it apart in, and of course whatever you do, don't apply too much pressure to the LCD; if you crack it, it's pretty much game over.
这个答案有帮助吗?
得分 2
2条评论:
I wasn't expecting such a quick response!
Thank you very much for your insight. I will try it out if I decide to keep it. I now know that if I do keep it, there is a good possibility of repair.
Have a great one!
由完成的
@bbcski I concur with @dadibrkeit. Looks like stains on the diffuser. You can fix it by disassembling the complete panel and cleaning the sheets. 2 things to be careful of. Do not bend the panel, secure the driver boards that are attached to the panel, with some painters tape. Next is to mark the order and the direction of how the sheets are inside the panel. They have to be re-assembled in the same order and direction.
由完成的
添加一条评论
添加你的答案
BenC 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 23
总计 483
