跳转到主内容
加入维修社区 - 创建账户
Audio-Technica 于 2019 年发布的唱机。
Start button is not doing anything
The belt is on correctly, and the manual reset did not help. The start button does nothing; almost as if there’s no power.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This is the best site for turntables I have been able to find:
Turntables, Tonearms and Cartidges
这个答案有帮助吗?
得分 1
1条评论:
Appreciate it! It looks like it might be a bad motor, so I'm probably in a position to replace, but I'll bookmark the site.
Cheers
由完成的
添加一条评论
You may need a multimeter to check if the motor itself is dead. If it is the motor, the replacement may be available via Audio-Technica directly. The part is weirdly hard to find online otherwise. you can contact them via email at parts@atus.com. (If in the USA, check your regional Audio-Technica site for a parts page otherwise.) It will, however require a bit of soldering to replace as two of its wires are connected to another board directly instead of via a push connector.
You can see details as to how to do this in this guide for its predecessor: Audio-Technica AT-LP60BK 电机更换
The internals are the exact same between the LP-60 and the 60X layout-wise. AFAIK the only major changes were in the physical appearance of the turntable. I would not recommend de-soldering while the motor is still in the unit (as in that old guide) as the entire shell is plastic. It's also just a big unit, which you already know due to owning one. It'd be annoying to work on it like that.
Does it indeed make a mechanical "click" when start is pressed?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeremy R. Stoll 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 19
过去 30 天: 109
总计 5,639
