跳转到主内容
加入维修社区 - 创建账户
Won't power up.
Won't power up. was getting 2 light blinks on standby. Replaced power supply. Didn't help. Replaced batteries in remote, rebooted. Started and worked fine for 30 seconds. then returned to startup failure. Standby light is giving one longer light followed by two short lights. Advice?
Update (07/01/23)
Actually it is a QN75.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@davidrayome just a quick thing to do. Disconnect your AC cable. Disconnect your main board from the power board and reconnect the AC power. Do your back lights come on? If yes, your power board is okay. Disconnect AC power, reconnect main board, disconnect the Panel. Reconnect AC power. Let us know what happens.
Next step would be, you showing us your boards and your interconnect cables etc. We will need large well focused images so we can try and assist you with determining what is going on with your TV. It's a large panel so I know this is not easy to work around.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Rayome 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 471
