跳转到主内容
The fourth generation of the sport utility vehicle known as a full-size Bronco, the successor to the early Bronco.
7 个问题 查看全部
My alt isn’t charging my battery. Keeps draining the battery
I have a 1990 ford bronco with a 5.8L I replaced the battery,alt, starter solenoid. I can drive about 3 miles or let it idol for about 20 min. Then if dies, just starts running rough then it dies. I can charge the battery to full charge but it don’t last long. It’s driving me nuts.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@joshuaclar26392 check all your ground and look for any signs of corrosion in the wires. Put your multimeter on your battery cables and, with your engine running, check the voltage. Anything below 13.75V means your battery does not get charged. Let us know what you get.
The next thing to check would be the fusible link coming of B+ and going to the battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Joshua Clark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 39
