跳转到主内容
加入维修社区 - 创建账户
三星 10.1 英寸 Galaxy Tab 平板电脑的第三代产品。
LCD screen Ribbon Connector
Hi,
So i have a random question. I had a broken samsung tab 3 and iv taken it apart for a project. I wanted to know is there a way to change the Ribbon Connector to a 40pin? Or is there away of taking the gray tap (not sure whats its called) to put a 40pin ribben cable to it and complete void the LCD board.
Update (06/23/23)
Hi sorry about that.
Im wating to reuse it for a rasberry pi by installing a Display Monitor Driver Board
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@learning201 the board we are looking at is the LCD driver board? Connected to your display panel? What is the exact model number for your tablet (GT-P5200?)
By using the display connector schematic, could you not determine which pin does what and move on from there.
由完成的
添加一条评论
1个答案
已选择的解决方案
if you add photos and the reason why you want to change to 40 pin then it will give people a better understanding of what you are trying to do
Update 06/23/23
@learning201 you would need to find out what each pin is for, some will be ground, others could be for single rails or you could have 2-3 pins connected to 1 rail
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Learning201 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 404
