跳转到主内容
2021年10月发布的14英寸MacBook Pro的维修指南和拆解信息,该产品采用苹果设计的M1 Pro和M1 Max SoC,型号为A2442。
Configuration by apple after screen replacement
Broken screen, I bought the same Macbook on eBay, missing a logic board. So I can swap the screen into mine. Then it will need configuration. If I take it into an Apple Store will they do this for me? And would they charge me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Sorry to tell you you can’t swap out the display’s, you can thank Apple for that! You need access to a paywalled Utility that Apple calls a calibration tool.
Here’s the web site to order the replacement Self-Servicing Account Program. You could try using the tool with your removed display to see if that works if it does just return the part unopened. I’m not sure if the site is fully hardwired to the replacement serial number or not, as I haven’t had a second display to try. If that works let us know.
这个答案有帮助吗?
得分 2
7条评论:
I just checked with apple repair. Posting the reply below. Seems like it might be trouble, if I say I repaired it and they run the configuration, then I say I want to return with it unopened, it is an obvious lie.
From Apple Repair
To return an order the unit needs to be in new, unused, unaltered condition and in the original unopened individual packaging within 14 days of delivery. Before we proceed, to verify the return will pass inspection, can you please verify that the individual boxes are still factory sealed?
完成的
@bravo0123 - 😢Sorry for the bad news.
完成的
can't you just put your logic board in computer u bought
完成的
I thought of that, but same problem? Isn't it the fact that the logic board and the screen are not a pair that causes the artifacts? Also then I would have the problem of the touch sensor not working.
完成的
I think I will just swap the screen, see how bad the artifacts are. then if necessary take it to an Apple Store to see if they will help.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
David Shanabrook 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 1,404
