跳转到主内容
加入维修社区 - 创建账户
OnePlus 9 5G 是一款中端智能手机,发布于 2021 年 3 月。它是 OnePlus 8 的继任机型,配备 6.55 英寸 120 Hz 流体 AMOLED 显示屏,并搭载高通骁龙 888 5G 芯片组。
LE2117 Battery replacement options?
Hi, looks like the BLP829 battery sold for the Oneplus 9 5G does not have the Tmobile variant (LE2117) listed as a compatible model. I haven't had much luck finding a Tmobile specific battery for this device, does anyone have any recommendations or know if the BLP829 will work on an LE2117?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Hey Zed I currently need to replace my LE2117 & OnePlus refuses to do it even with me offering to pay the labor and parts fees. I was wondering if the replacement battery is still holding up? And if so, did it seem new after initially installing it?
由完成的
添加一条评论
2个答案
已选择的解决方案
Hi, the BLP829 battery will not fit in a model LE2117 for T-Mobile in the US. You may need to find a different battery model that is compatible with your device. You can use the Oppo BLP821 battery2, which has the same voltage and capacity as the BLP829 battery, but you should check the dimensions and connector type before buying it. Alternatively, you can contact OnePlus customer service and ask them for a recommendation or a replacement service.
这个答案有帮助吗?
得分 3
3条评论:
Thank you, i ordered the Oppo BLP821 and it fits and functions perfectly.
由完成的
From where did you purchase it?
由完成的
Thank you Zed for confirming the BLP821is the right replacement battery for my One Plus 9...LE2117 phone. It's definitely saved me a lot of time and frustration.
由完成的
添加一条评论
Hi Zed, the BLP829 battery won't fit in a model LE2117 for T-mobile in the US. You can use the Oppo BLP821 battery which has the same voltage and capacity as the BLP829. I hope this answer can help you.
这个答案有帮助吗?
得分 1
1条评论:
Thank you Holly, for that valuable information because I was about to purchase the wrong replacement battery. I research to find the right replacement battery and Google said I needed the BLP829. I am glad I read the comments before I place my order.
由完成的
添加一条评论
添加你的答案
Zed 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 46
总计 2,609
