跳转到主内容
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
Why is my laptop bot starting up?
Hi. The laptop battery was removed after giving error to be replaced and i was able to use it while plugged in without the battery for almost a year. Now its not turning on on giving 4 beeps with black screen.
Any help please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @t1oug6kbgzez56e
A 4 beep error code indicates a memory read / write failure.
Disconnect the power to the laptop and try reseating (remove/replace) the memory module and check if that resolves the problem.
Here's the owner manual for the laptop that may help.
Go to p.15 to view the procedure. Assuming that the battery is still not installed, you can skip the pre-requisite step.
If it is still no good after trying this it may be a faulty memory module. According to the specifications it uses DDR4 2400 SODIMM ram, 8GB max.
Try inserting a new compatible ram module and check if it works OK. If not then there's a problem on the motherboard
这个答案有帮助吗?
得分 1
4条评论:
Thank you Jayeff Im going to try that
完成的
It didn't work unfortunately.
完成的
@t1oug6kbgzez56e
I assume you mean that reseating the memory module didn't work, is this correct?
If so you'll have to replace the memory module, with a compatible new or known working memory module and then check. It's the only way to know whether the problem is with the module or the motherboard
完成的
Hi. Yes that's correct. I will replace the memory module and give feedback. Thank you very much for the assistance.
完成的
添加一条评论
添加你的答案
dendalene 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 91
