跳转到主内容
加入维修社区 - 创建账户
Kenmore 推出的热门系列衣物烘干机。
My dryer does not stop automatically.
The timer does not shut down the dryer automatically. You can turn it off by turning it manually clockwise.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @bert42849,
What is the model number of the dryer?
完成的
添加一条评论
2个答案
最有帮助的答案
Does it shut off when you open the door?
这个答案有帮助吗?
得分 1
2条评论:
No, it does not stop when you open the door. The timer does not count down to the stop point. When you turn it clockwise to the stop point everything works fine. It’s like manual mode. Only to stop it from continuing to dry.
完成的
yes it shuts off when i open the door
完成的
添加一条评论
@johnzechnersr, without the model number of your dryer we can't be specific, but the times when I've seen this situation it's been due to the timer motor dying. The timer operates with a motor that rotates the dial very slowly, and when that motor craps out, you get this situation - everything works as long as you advance the timer by hand.
I've been able to test it by taking the timer switch out and manually wiring the timer motor up to 110V. Obviously you'll want to verify that's the correct voltage for yours before doing that. Take a marking pen and mark any random position on the timer dial, then leave the timer connected up to power for like 15 minutes. If the mark hasn't moved, you need a new timer motor.
It's a crapshoot as to whether you're going to be able to buy just the motor itself, or you'll end up having to replace the whole timer; it all depends on which model you have, since Sears used several manufacturers to build their Series 80 dryers. Again, the model information is critical for finding the right parts.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bert 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 331
