跳转到主内容
加入维修社区 - 创建账户
任天堂的 Game Boy Advance(GBA) 掌上游戏机 于 2001 年发布。维修它只需要常用工具,而且不需要电热工具处理。
How should I remove rust on the battery terminal?
Hello! I just bought this Game Boy Advance today and noticed that there was rust on the battery terminal. It still works fine, but the power indicator light flickers from green to red, probably because of the poor battery connection. It is only on this one terminal, so I want to try to clean it off. What is the best way to do this without damaging the motherboard? I could also replace the terminal but I would rather keep the OEM one.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Bex bw-100 electrical contact cleaner is a good option as well as 91% or higher isopropyl alcohol.
Oxo makes a slicone cleaning tool with a blade like nib and a brush that I highly recommend
Qtips are also a valid option
If there is any tough corrosion you can GENTLY pick and scrape at it with ifixit's sharp tweezers.
这个答案有帮助吗?
得分 0
添加一条评论
Instead of disassembling the terminal to replace it, you can also disassemble/clean/reassemble the OEM one, for example see this post from DigiKey or this one (it works for battery terminals in general). If you can't disassemble it, do not use liquids for cleaning (usually you don't want them near anything electronic) but something like a brush to remove as much "rust" as possible
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bailey Bryan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 596
