跳转到主内容
加入维修社区 - 创建账户
KitchenAid 5.5/6.0/7.0 夸脱升降式厨师机(型号:KSM55/KSM60/KSM70)(包括重新设计的优质触控点型号)是 2022-2023 年发布的一系列升降式厨师机。该系列厨师机取代了此前众多的升降式厨师机型号。它们具有多项改进,包括:更坚固的齿轮箱设计、更安静且更高效的交流电机,以及新增的 1/2 挡速度设置。
Is there a replacement guide for new version?
I have new version which has a model number: ksm55sxxxcu.
I have some control card failures so I would like to replace the card. But the is at the bottom of the motor . To reach the card you must take the motor out first. But motor has a conjuction with the tip and i could not seperate the motor from the tip.
is there a guide for the new version describing how to take the control card out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi, these guides apply to your mixer as well. The control board is called the Speed/Motor Control Assembly. You can use the guide in this device for your model for opening and replacing the control board. Internally, the KSM55/KSM60/KSM70 are identical with only minor part number differences.
I have been gradually updating the guides to include the correct part numbers for all mixers in the KSM55/KSM60/KSM70 lineup (e.g., the Power Cord Replacement Guide for this model). In the meantime, until I can incorporate them in all of the guides, I have uploaded the Repair Parts List for your model to the device main page. The part number for the Speed/Motor Control Assembly is W11503693.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
levent ercan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 881
