跳转到主内容
加入维修社区 - 创建账户
GE 冰箱 GFE26JGM**** 的维修及附加信息。该款自动除霜冰箱无制冰机或门上分配器,于 2019 年首次上市。本页面包含符合 GFE26JGM**** 型号格式的相关信息。
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
Update (05/05/23)
  • trying again
Update (05/05/23)
GFE26JGMWFBB is the model
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
can you add photos
完成的
@dougwilds i can't see them doug it just says image
完成的
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
完成的
添加一条评论
1个答案
最有帮助的答案
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Doug Wilds 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 593
