跳转到主内容
The Sony Ericsson W580i is a walkman style slider phone with a 2 megapixel camera.
4 个问题 查看全部
Accidentally connected about 11 volts
I accidentally connected 11 volts instead of 3.6 as the battery has died then the screen flashed for a brief moment and it has been dead since
Does it have something like a fuse if the whole phone is dead
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
[br
@incp|new_window=true] where and how did you apply that voltage? I expect the battery and the power management IC to have gone up in smoke. Possibly more components. Time to open it up and tear it down to see what got damaged. Sony Ericsson W580i Repair Once you are at the motherboard check around the charging port and inspect all the components. For anything odd etc., post some pictures of it with your Question. that way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
I don't know where and you did apply that high voltage. I except that the charging port and power management IC have been gone in smoke. If you haven't opened your Walkman after the voltage damaged it, possible more components (like internal flexible cable, display, LCD flexible cable, front keypad UI and keyboard UI) have been destroyed. Phones don't have a fuse if it is dead.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Incp 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 47
