Accidentally connected about 11 volts
I accidentally connected 11 volts instead of 3.6 as the battery has died then the screen flashed for a brief moment and it has been dead since
Does it have something like a fuse if the whole phone is dead
@incp|new_window=true] where and how did you apply that voltage? I expect the battery and the power management IC to have gone up in smoke. Possibly more components. Time to open it up and tear it down to see what got damaged. Sony Ericsson W580i Repair Once you are at the motherboard check around the charging port and inspect all the components. For anything odd etc., post some pictures of it with your Question. that way we can see what you see. 在已经存在的问题里加入图片
这个答案有帮助吗?
I don't know where and you did apply that high voltage. I except that the charging port and power management IC have been gone in smoke. If you haven't opened your Walkman after the voltage damaged it, possible more components (like internal flexible cable, display, LCD flexible cable, front keypad UI and keyboard UI) have been destroyed. Phones don't have a fuse if it is dead.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 43
