跳转到主内容
A 7" tablet with a Android 4.2 (Jelly Bean) operating system.
Are the lcd displays swappable for this tablet?
I replaced the digitizer top glass, but the lcd display underneath is also ruined. A new lcd display costs more than a used identical device. So if it's possible, I'd either take the lcd display from one I buy used, or if it's easier I'd put the storage or motherboard into the used one I just bought.
If anyone has an answer, I'd appreciate any info or advice. The tablet has photos and videos that are of sentimental value, which is why it's worth all this effort for me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi Robin,
You have several options for your tablet available. As you mentioned, yes, you can indeed buy another used one and disassemble it for the LCD. From my reading of the replacement guide, it's going to be the same amount of work to either replace the LCD on yours or swap your motherboard into another system. If you've replaced the digitizer then you already know exactly how much work it is.
Anyway, for your reference here's the iFixit guide for replacing the display on your tablet.
RCA RCT6272W23 Display Replacement - iFixit Repair Guide
As far as finding a replacement LCD, there's one seller on eBay right now selling them for US $25.89, which isn't bad for a new screen.
New LCD Display Screen Replacement for RCA RCT6272W23 7 Inch Tablet F88
I didn't find a lot of others, but if you remember that RCA doesn't make their own LCDs, you can probably look on the back of the LCD itself and get the manufacturer and model number and search for parts using that number instead.
Good luck; be sure to let us know how it turns out for you!
这个答案有帮助吗?
得分 2
添加一条评论
@robinboyles this "take the lcd display from one I buy used" might be the better idea. The display removal is actually pretty straight forward. It is also solid enough that it should not get damaged. RCA RCT6272W23 Display Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Robin Boyles 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 183
