跳转到主内容
加入维修社区 - 创建账户
RCA RCT6272W23 Display Replacement
你所需要的
    1. RCA RCT6272W23 Display Replacement, Case: 步骤 1 中的图像 1,2 RCA RCT6272W23 Display Replacement, Case: 步骤 1 中的图像 2,2
      • Use a Phillips #00 screwdriver to remove both 4.1 mm screws at the top of the device which hold it together.
      询问修复机器人
      添加评论
    2. RCA RCT6272W23 Display Replacement: 步骤 2 中的图像 1,2 RCA RCT6272W23 Display Replacement: 步骤 2 中的图像 2,2
      • Press the plastic opening tool into the space between the front and back portions of the case.
      • Run it along the perimeter of the device to unhook the plastic tabs.
      • Gently pull both sides apart.
      • The speaker is connected to the back cover, so be careful when separating.
      询问修复机器人
      添加评论
    1. RCA RCT6272W23 Display Replacement, Motherboard: 步骤 3 中的图像 1,3 RCA RCT6272W23 Display Replacement, Motherboard: 步骤 3 中的图像 2,3 RCA RCT6272W23 Display Replacement, Motherboard: 步骤 3 中的图像 3,3
      • Use a soldering iron to remove the soldered connections on the motherboard
      • For your safety and to ensure a correct repair, be sure to exercise caution when using the soldering iron.
      • For more information about soldering, check out this guide.
      添加评论
    2. RCA RCT6272W23 Display Replacement: 步骤 4 中的图像 1,1
      • Use a philips #00 screwdriver to unscrew the three 4.064mm screws which attach the motherboard to the front of the device.
      询问修复机器人
      添加评论
    3. RCA RCT6272W23 Display Replacement: 步骤 5 中的图像 1,2 RCA RCT6272W23 Display Replacement: 步骤 5 中的图像 2,2
      • Use your fingers to pop the three black tabs up to release the flat plastic data transfer cables.
      询问修复机器人
      添加评论
    4. RCA RCT6272W23 Display Replacement: 步骤 6 中的图像 1,1
      • Pull up the motherboard from the rest of the body.
      询问修复机器人
      添加评论
    1. RCA RCT6272W23 Display Replacement, Display: 步骤 7 中的图像 1,1
      • Using a plastic opening tool, pry the battery off of the rest of the body.
      • The battery is attached to the display with double sided tape. It may be best to have a new strip of double sided tape to reattach the battery.
      询问修复机器人
      添加评论
    2. RCA RCT6272W23 Display Replacement: 步骤 8 中的图像 1,3 RCA RCT6272W23 Display Replacement: 步骤 8 中的图像 2,3 RCA RCT6272W23 Display Replacement: 步骤 8 中的图像 3,3
      • Using a spudger, separate the display surface from the front cover.
      • Be careful not to break the tabs that hold the display screen in place.
      • A second spudger may be necessary to help hold the position of the display screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
团队
Michigan Tech, Team 1-5, Lauer Spring 2015 Michigan Tech, Team 1-5, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G5
2 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 29
总计 2,628
