跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch Joy-Con 手柄的维修指南和相关信息。
Joy Con not functioning when physically attached to Switch
The Switch was dropped, I replaced the right red joy con’s rail. It now functions fine when wireless, but will not work when physically attached to the switch. The Switch shows the attach animation, when it is attached, but then fails to recognize it and does not accept any input from the joy con.
I then replaced the rail on the actual console, and I get the same error. I have deleted and re-paired the joy cons, and rebooted the switch, and joy con, and still have the same issue. All connections on the joy con have been detached and reseated, and I think have the same issue.
Any thoughts?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
do you have an extra joycon or switch you can use for testing?
由完成的
添加一条评论
1个答案
Hello! Since the Switch console can recognize a joycon being attached, I think this is an issue with the controller instead of the Switch. There is a connector on the bottom of the rail on the side of the joycon that I think might send button inputs to the Switch. If the joycon looks fine, make sure the ribbon cable on the Switch console’s rail is fine and that it is plugged in all the way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Steven Boughton 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 15
过去 30 天: 34
总计 4,100
