跳转到主内容
加入维修社区 - 创建账户
Change the thermal paste
How to change the thermal paste on the processor of Legion laptop
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
If you are experiencing high temperatures or your Legion laptop is overheating, it may be time to change the thermal paste on the processor. Here are the steps to follow:
  1. Turn off the laptop and unplug it from the power source.
  2. Remove the back cover of the laptop. This will require unscrewing several screws on the back cover.
  3. Locate the CPU and GPU on the motherboard. The processor will be covered by a heatsink.
  4. Remove the heatsink by unscrewing the screws that hold it in place. Carefully remove the heatsink, being sure not to damage the processor.
  5. Clean the old thermal paste from the processor and heatsink using a clean cloth or cotton swab and isopropyl alcohol.
  6. Apply a small amount of new thermal paste to the center of the processor. Be sure to use only high-quality thermal paste.
  7. Replace the heatsink on the processor and screw it back in place.
  8. Reattach the back cover of the laptop and screw it in place.
  9. Turn on the laptop and check the temperature of the processor using a monitoring software. You should notice a decrease in temperature after changing the thermal paste.
Changing the thermal paste on the processor of your Legion laptop can help improve its performance and prevent overheating. However, if you are not confident in your ability to do this, it is best to seek professional help.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
hi @monkey86988
Here's the hardware maintenance manual for the laptop.
Go to p.63 to view the procedure to remove the thermal module. This will allow you to access the CPU and the GPU so that the old thermal paste can be removed and a fresh coating applied.
Here's the ifixit 如何涂散热膏 guide that will also help.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
monkey 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 28
过去 30 天: 127
总计 7,350
