跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
122 个问题 查看全部
Why does my pc freeze whenever I boot up a game?
My Pc keeps on freezing when I boot up certain games or close games, an example would be when I close Fortnite, my pc will freeze and I have to restart it using a button on my case. It started when I tried to upgrade my ram but it messed up my pc and gave me a BSOD but I fixed it (i think). I was thinking all my problems started from that but I'm not sure. I also plan on upgrading my PC to see if it's also that.
My specs
  • CPU: Ryzen 3 3200g
  • GPU: 1660 Super
  • Motherboard: B450 bazooka max wifi
  • Ram: 8gb DDR4-3200
  • Power Supply: 500w 80+ bronze
  • Storage: 1tb + 500gb
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Without more information I am going to assume this is a RAM issue. You have 8gb of RAM but you don't actually have 8gb because your OS (I am going to assume windows) you only have roughly 4gb (+or - 1gb) to play with. You may be skirting by on the 8gb but closing the game or doing literally anything else to increase your RAM usage will BSOD your system. Try giving at least 12 and seeing if that improves anything.
Also If your computer image is old I would suggest blowing it out and starting fresh. IE reimage your system. Don't factory restore it. This will generally just improve performance.
这个答案有帮助吗?
得分 2
2条评论:
So how would I fix it? I'm a bit confused
完成的
Give it more ram you are capping out on ram.
And if you haven't try reimaging your system as well sometimes starting fresh fixes most issues.
完成的
添加一条评论
添加你的答案
ThatOneSkittle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 40
