跳转到主内容
加入维修社区 - 创建账户
微控制器(也称为 MCU,即微控制器单元)是放置在单个金属氧化物半导体 (MOS) 集成电路 (IC) 芯片上的小型计算机。
Help! My Ethernet Adapter is Overheating
Hi everyone,
I'm facing a problem with my Ethernet adapter, which seems to be overheating. I'm not sure why this is happening, but it's causing some serious issues with my internet connection. I've tried unplugging the adapter and letting it cool down, but the problem persists.
I'm not very tech-savvy, so I'm hoping some of you can offer some advice. What could be causing my Ethernet adapter to overheat? Is there anything I can do to fix it? Do I need to replace it altogether?
Any help would be greatly appreciated. Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
How are you diagnosing this? You pointed to a hub switch which should offer a RMON probe to monitor hardware and packet issues.
Did you try a different port or swap out the sub module or see if the uplink module is just carrying the errors forward from the down stream connection.
这个答案有帮助吗?
得分 0
添加一条评论
I had this same problem ,and popped 2 adapters .I read an article about usb connecters being loose and causing a restart (on the adapter) (using more voltage) - made 3 plastic strips from an old credit card and filed tapered edges -and made shims for each usb port -now my new adapter stays fixed in usb port and it seems my overheating problem has disappeared, no longer burn my hand hot
这个答案有帮助吗?
得分 0
1条评论:
This is a Hub Switch which has a backplane connection not USB based.
由完成的
添加一条评论
添加你的答案
geoargeanderson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 63
总计 1,518
