跳转到主内容
Repair guides and support for your Philips TV.
242 个问题 查看全部
Backlight on but no picture
Hi everyone I got Philips tv with no picture but with sound and backlight on.When I unplugged left or right ribon going from t-con bord to panel , left or right side of panel will work so I assume that panel is OK....Is that sign of bad t-con or main board?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@nicktree85 yes and no. Yes , your panel itself is okay, but (big but) your panel driver may not. A failed T-con board would not give you a picture on both sides. Of course, like anything else in life, things change. So, who know Philips may have something up their sleeve. Anyhow I would check the voltages on the T-Con board. Specifically, you want to find VGH on the T-cno board. Measure that with a multimeter in DC mode. Then you will have to go and find it and measure it on the driver boards. Those are the boards that are connected to the LCD panel via fine ribbon cables. The are not removable (by the DIY'er) Let us know what coltages you can find. It might also help if you post a few pictures of all of your boars with your question. That way we can try and assist you with that. 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Martin Bardiovsky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 66
