跳转到主内容
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
84 个问题 查看全部
My original DS won't keep a charge.
Just a got an original DS, and when I plug in the charger cable, the orange light turns on for a second or two and then goes off. And not because the DS is fully charged either because it won't turn on. What should I do to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Oddmegaman9 9 first check and possibly replace the battery. It is entirely possible that it will no longer hold/accept a charge. After that, you need to check your charger to make sure that it provides proper voltages. Then you charging port. Make sure there is no debris, corrosion or bend pins on it. If all of that checks out okay, you will need to disassemble your DS and check the charging port connection to the circuit board and check the overall traces of your board. Use this guide Nintendo DS Main Circuit Board Replacement to get there. Post a couple of pictures of what your main board looks like so we can try and help you further. It is also possible hat this is happening because of other damage to the DS and it does not allow it to turn on. So, check the flex cables, connectors etc. as wella s the LCD. Just out of curiosity, has it ever worked for you. Do you know as a fact that you purchased a working model.在已经存在的问题里加入图片
Nintendo DS Motherboard replacement.图片
指南
难度:
中等
10 - 15 minutes
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Oddmegaman9 9 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 63
