跳转到主内容
加入维修社区 - 创建账户
DYMO LabelWriter 450 是一款适用于家庭和办公环境的专业级标签打印机。型号:1750283
How do I replace ink cartridge?
Black ink is running low and not sure how to get to it to replace it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @keithpl,
Please verify the make and model number of the device that your question is about.
The Dymo LabelWriter 450 doesn't use ink. It is a thermal printer. The printer uses heat from a thermal print head to print on specially treated, heat-sensitive labels
由完成的
I have a Dymo LabelWriter 400 Turbo, do I need to replace the ink cartridge or is there no ink on this model too?
由完成的
@brenda27832
All 400 series Dymo LabelWriters are the thermal print type i.e. no ink
由完成的
添加一条评论
1个答案
最有帮助的答案
This is a termal printer, it does not use ink or toner, chances are your battery needs charging or replacing.
这个答案有帮助吗?
得分 1
2条评论:
Why do I need a battery for the thermal printer if it has an electrical plug?
由完成的
@gailstewart You are correct that the LabelWriter series are all corded. Are you having the same problem as the original question, of the printing fading out?
由完成的
添加一条评论
添加你的答案
Keith 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 63
总计 2,545
