跳转到主内容
加入维修社区 - 创建账户
适用于办公室中常见的滚动办公椅的维修信息。
The base of chair
The middle pole of the chair is longer than the wheels now. This happened during moving can it be repaired?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
Can you add a Image of what it looks like?
完成的
Here’s the guide for adding photos
在已经存在的问题里加入图片
完成的
@hellomacos - Thanks!
完成的
添加一条评论
1个答案
已选择的解决方案
Good evening E Cole.
We repair office chairs in Pretoria, South Africa. If interpreted your question correctly. The gas is sticking to the ground and the wheels is off the ground, or unstable. So firstly, the cause of this is mostly due to an old gas cylinder that no longer has the spring effect to it when you go and site down. This causes direct weight transfer through the cylinders housing onto the base, so every time you go and sit it goes through the base bit by bit, until it cracks the base and sticks right through to the bottom.
So in short, you can replace the gas cylinder and the base with new ones. This will have your chair in working condition in no time.
If this is not the problem you are experiencing my email address is on my website, not sure if i am allowed to post it here. Feel free to drop me a mail with some images, i will gladly assist and help where i can. Have a great evening.
这个答案有帮助吗?
得分 1
2条评论:
@xeptortech post your business address, email etc. in your About page, not on the individual answer. You can refer to that page in your answers. Anything else is treated as Spam ;-)
完成的
Hi oldturkey. Will do. Still need to get the hang of the site. Appreciate it
完成的
添加一条评论
添加你的答案
E Cole 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 59
总计 1,025
