跳转到主内容
dryer that is getting way too hot
I have an older Maytag de107 dryer that is getting way too hot. Red hot and stays red. If I’m reading right the dryer only had two thermostats one is the cycling and the other is hi temp thermostat. I replaced the hi temp it didn’t help. Took the heater element and it’s case out checked the coil no breaks and no short. So see another thermostat up front along the air exhaust and fan is that the cycling thermostat? And is there any more that im not seeing? The lint is cleaned out. But I noticed like a pile of ? I want to say burnt shavings of what I don’t know at the back of the heater element casing. Please help don’t know what to do next. Replace the cycling thermo??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@edges the cycling thermostat is definitely what I would change next. The hi temp will stay high without a functioning cycling thermostat. My concern are those "burnt shavings". Take a couple of pictures if you can of what this all looks like and post those with your QUESTION so we can see what you see. Also, do not forget to check the airflow , so check your blower and check your exhaust vent.
在已经存在的问题里加入图片
Here is the service manual for the DE series Maytag Dryer DE Series Not the greatest but a start. the thermostats are usually in the blower housing.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Deb 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 43
