Making the volume louder than the manufactured setting.
I have my volume all the way up. How do I make the phone even louder?
@michael4114 if you want more volume then the phone is designed to provide, all you have to do is to redesign the logic board circuitry. Design it around the audio amp and the audio codec IC to whatever power that you need it to be.
As you can see this is just not an easy question to answer. If you need bigger volume, get a Bluetooth speaker set up. You can then "crank it up" to your hearts contend.
这个答案有帮助吗?
Hi
As well as the amazing answers from @oldturkey03 and @danj you could also get a external amp and DAC for your phone and use it with headphones
Hopefully this helps
Any questions please ask
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 24
总计 255
