跳转到主内容
Oculus Quest 2 是 2019 年 5 月 21 日发布的 Oculus Quest 的继任者。Quest 2 是一款经过改进的型号,具有更好的处理器和重新设计的触摸控制器。
Won’t switch on
Won’t turn on after dropped
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
is there any damage you can see on the outside? was it dropped from a high or low place? was it dropped on hardwood/tile/concrete or carpet? did you drop the headset or the controller? could you add some photos if theres any external damage please?
在已经存在的问题里加入图片
完成的
Sorry for the late response. No visible damage won't turn on after charging just system showing flat battery in goggles then disappearing it was dropped onto carpet from my 9 year old daughters head
完成的
添加一条评论
1个答案
最有帮助的答案
This question is already covered in the "Meta quest ™" Manual.
If you search this up it says"
Dropping it, especially on a hard surface, can potentially cause damage to the headset and battery. Inspect your headset for visual damage before each use. If you suspect damage to your headset or battery, contact Oculus Support. "
The online manual is downloadable on the web.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ianj117 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 203
