跳转到主内容
Apple 的第三代智能手表,配备可选的蜂窝网络功能,发布与2017年9月22日。
197 个问题 查看全部
Apple Watch Series 3: Should I replace my battery?
Hello!
I have an Apple Watch Series 3 that has been in storage for a long time: 3 years. However when I first opened up the box, the watch does not turn on. I have tried charging it, but no luck. No vibrations, or screen life. Nothing works even with a "hard" reset. However whenever I charge it, the watch does get warm. I was wondering if this is a battery issue, or could be a display issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@kneemo based on this "that has been in storage for a long time: 3 years", absolutely. The Apple Watch battery will have to be discharged below it's threshold and will definitely no longer hold a charge. Replace the battery, then re-evaluate. Apple Watch Series 3 电池更换
这个答案有帮助吗?
得分 1
2条评论:
Appreciate the response! Even though it gets warm, does it mean the battery is active though?
完成的
@kneemo getting warm could just be from your charging circuit trying to charge the battery. It means a charge is applied but will not get stored
完成的
添加一条评论
添加你的答案
Ronald 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 78
