跳转到主内容
加入维修社区 - 创建账户
HP EliteBook 840 G3 的维修信息。这款惠普笔记本电脑专为企业应用而设计。
Booting device not found 3FO error
All of the sudden my pc is not opening it is saying booting device is not found... I tried to get in to bios and try to fix it but it's asking me bios administration password and I don't know it.
Am a student and I need help as soon as you can, exam is around the corner.
Thank you for your time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
For starters follow the steps below to run HP Diagnostics.
  • Restart the computer.
  • As the computer boots, press the ESC key when the HP Splash Screen appears.
  • When the Startup menu appears, press F2 to enter System Diagnostics.
  • Run the Hard Disk Test in System Diagnostics
  • Best to test everything but especially the hard drive.
Let us know what you get. You may be interesed in the discussion below.
It is possible that the hard drive is defective or corrupted.
Look on the web. There are several bootable USB flash drive diagnostics, etc. to check and even repair your non-booting hard drive.
这个答案有帮助吗?
得分 1
3条评论:
Hi @aactech,
Don't know HP that well but can you enter diagnostics without knowing the admin (BIOS) password?
Cheers
由完成的
Hi @jayeff Happy New Year!
Good question.
What I can tell you is that at power on-
Pressing<F2>takes you directly to System Diagnostics.
Pressing <F10> takes you directly to the BIOS Setup screen.
Pressing <ESC> takes you to the Menu Screen where <F2> takes you to System Diagnostics or <F10> to the BIOS setup page, <F7> takes you to Spare Key explained here:
https://h30434.www3.hp.com/t5/Notebooks-...
I have never personally used nor recommended that password to any clients as it causes more problems than it is worth.
So to answer your question I don't know for sure.
由完成的
@aactech
Happy New Year to you too. ;-)
Thanks for that.
Cheers
由完成的
添加一条评论
Well try these fix
  1. Turn off the computer and wait five seconds.
  2. Press the power button to start the computer and repeatedly press the f10 key to enter the BIOS setup menu.
  3. On the BIOS Setup screen, press f9 to select and load the BIOS Setup Default settings.
  4. Press f10 to Save and Exit.
For more you should read this: https://support.hp.com/in-en/document/is...
这个答案有帮助吗?
得分 0
1条评论:
F9 isn't responding
由完成的
添加一条评论
添加你的答案
Ayub Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 22
总计 2,710
