跳转到主内容
A1013、A1052、A1085或A1107/1440x900屏幕分辨率
121 个问题 查看全部
Location of jumper pads for logic board for internal restart
I got in a A1107. Just fan noise on startup. Did the usual battery tests, AC stuff, SMC, tried PRAM reset to no avail. Removed hard drive for data recovery and get flashing lights on my universal adapter but cannot access the hard drive. My thinking is that this faulty hard drive may have prevented booting. Can someone confirm this? Also are there power jumper pads on this machine and where are they located?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I don't have this logic board to identify the two power pads but check for a power icon or the letters PW BT written on the logic board probably in the top case connector area. I think there are also two pads to reset the logic board written RESET over them.
完成的
添加一条评论
1个答案
已选择的解决方案
mayer, this might be the stuff you are looking for.
这个答案有帮助吗?
得分 5
3条评论:
mayer, could you check and the see if this is the document for your computer
完成的
Would you happen to have a copy of that document oldturkey03?
完成的
email me. My address is in my user profile. Just click on my avatar....
完成的
添加一条评论
添加你的答案
mayer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,880
