跳转到主内容
加入维修社区 - 创建账户
苹果 2021 年的顶级智能手机。iPhone 13 Pro Max 于 9 月 24 日发布,配备 6.7 英寸 ProMotion OLED 显示屏、全新的后置三摄系统以及 5G 连接功能。它是 iPhone 12 Pro Max 的继任者。
Charging port sizing question
I see under the iPhone 13 Pro that there is a charging port replacement piece, I have an iPhone 13 Pro Max I am looking to repair and was wondering if I could use this piece?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Hi Rachelle,
No, unfortunately it's extremely rare for Apple to reuse parts between different models of its phones. Some of the SE series phones do reuse parts from a previous model, but I don't know of any cases where you can use a part between a regular and a Plus or Max version. The lightning connector assembly for your phone is not compatible with the 13 Pro; you'll need one specifically made for the 13 Pro Max. Here are a couple that came up on a cursory search.
Apple :: iPhone Repair Parts :: iPhone 13 Pro Max Parts :: iPhone 13 Pro Max Charging Port Connector Flex Cable - Graphite
For Apple iPhone 13 Pro Max Dock Connector Charging Port Audio Jack Flex Cable
Note that the charging port has a color option to match it to your phone; the first one listed is in the Graphite color, while the eBay listing has options for all available colors. You can use any of them, but there will be a color mismatch just inside the opening to the port that will be visible when the charger isn't plugged in.
这个答案有帮助吗?
得分 1
添加一条评论
no, 13pro and 13pro Max are similar but have different flex size (and its a only one difference). Design of the motherboard does not allow to bends of the tape (not enough space for it). See attached files :
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rachelle 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 28
总计 1,001
