跳转到主内容
加入维修社区 - 创建账户
于 2017 年 6 月发布,型号为:SM-J530F
doesn't have power
How repair if no power?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Bocs Endaya you want to start by making sure you are charging the battery. Check your charger to make sure it has proper output. Next, check your charging cable. Make sure that the ends are ok and no bend pins or debris in it. After that, check your charge connector. Same here, make sure the are no bend pins, corrosion or debris. Use a USB ammeter and check to see how many amps your phone pulls. If it does "pull" proper amperage but does not hold a charge, you want to replace the battery. If it does not, you need to check the charge connector. After that you will need to check your board. Use the Samsung flowchart
to go step-by-step
Use the component layout and your PDF readers search function, to locate the components to check J5 Component Layout
To work on your phone use something like this video
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Bocs Endaya 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 391
