Software problem related to charging
I have a wired problem that I assume caused be a software problem. My airdots was working fine but 3 months ago this happened. When i am using both airdots it takes about 10 minutes then die. I try to open them again but then died again after a minute(Note: the phone shows that the airdots is 10%) so it is detected as if it is out of power. But after dieing if i turned on any dot and used it solely it works fine and lasts for the normal time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Did you try factory resetting them? https://www.hardreset.info/devices/xiaom...
由完成的
添加一条评论
