跳转到主内容
加入维修社区 - 创建账户
Model A1013, A1052, A1085, or A1107 / 1440x900 screen resolution
PowerBook g4 not recognizing SSD
I have a PowerBook g4 I been having trouble with the laptop. The hard drive is still in the computer and it reads it just fine but when I replace the hard drive with the SSD it doesn’t read it. But when I plug in the SSD externally it reads but does not boot from it. I was wondering if I can have some help with this problem I really want to make this laptop run like new again like it did back then.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
And same thing go for my Mac mini g4.
由完成的
Jordan Chapman sounds to me like your G4 does not recognize the SSD as a boot drive. I would reformat the drive, then install the OS . The PowerBook G4 is the last laptop Apple made with the PowerPC CPU so your OS choices are very limited.
由完成的
添加一条评论
1个答案
已选择的解决方案
You need to install the OS properly. I’m suspecting you did a copy and not a proper install.
这个答案有帮助吗?
得分 1
5条评论:
Yea I did a copy
由完成的
What format do I need format the SSD?
由完成的
@Jordan Chapman - You need the original Grey CD’s that came with the system or get the retail version of OS-X Leopard (10.5.8) being the highest this system supports.
Using it to boot your system you should be able to reformat the drive and then install a fresh OS using the OS installer app.
由完成的
Do you need the dvd copy or can you use a iso to do it?
由完成的
@Jordan Chapman - You need the Bootable version of the CD.
You’re stuck in a bit of a catch22 problem!
You need the original drive in your system so it can run and then using an external SCSI case to house your new SSD then you can format and install the OS from the ISO image from your HDD.
由完成的
添加一条评论
添加你的答案
Jordan Chapman 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 33
总计 492
