跳转到主内容
加入维修社区 - 创建账户
燃气和电热水器、锅炉及家用热交换器的维修指南和支持。
pressure release valve leaking
how to replace the valve
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @tongrick,
What is the make and model number of the water heater?
Have you operated the release lever on the pressure relief valve so that it opens to release the pressure in the tank, then release the lever so that it closes again and check if it stops leaking?
It may take a few minutes to stop dripping until it finally closes fully again.
完成的
添加一条评论
1个答案
pressure relief valves do develop leaks and can be easily replaced. However, after my neighbor did that his tank started leaking. The two were not connected, the heater was just old.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for the answer.
完成的
添加一条评论
添加你的答案
RICHARD TONG 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 33
总计 343
