跳转到主内容
加入维修社区 - 创建账户
由市售 DIY 零件组装而成的台式电脑,而非来自大型制造商的预装机。这些电脑也可以由系统集成商使用市售零件来组装。
New psu not workin
Hi, i recently upgraded to a 3060ti and with that a New psu but with it my pc is not turning on, whenI try with my old psu my pc still works fine but not with the New one, i have tried reseating the cables many times but no succes, when i plug the New psu into the wall my gpu/psu fans start for a brief moment and then stop again and pc wont turn on, any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
14条评论
@finiego what are the make and model of your old PSU and same for your new PSU?
完成的
@oldturkey03 no they are not
完成的
@finiego @oldturkey03 was asking what the make and model is of both your old, and your new PSU
完成的
@geirandersen thanks brother :-)
完成的
@oldturkey03 oh sorry, the old one is FSP group Inc and the New one T.F.skywindintl both server psus, because my case is small
完成的
显示更多的9条评论
添加一条评论
1个答案
最有帮助的答案
@finiego I’d seriously suggest getting a multimeter(maybe borrow one from a friend). It must be able to measure DC voltage (just about every digital multimeter does). Connect the old PSU to power (doesn’t have to be in the PC) and measure each pin. You need to find one GND and put the black probe on that. Then go over every pin and check with the red probe. That should read either 12V, 5V or 3.3V (only on the new PSU!). Write it down, I like to draw a picture of each plug and write voltages on each pin, with arrows.
The do the same on the new PSU. Once complete, compare the readings and see if everything corresponds.
The old PSU only had 12V and 5V, while the new one also has 3.3V
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Fin Faas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 24
总计 506
